Old 12-10-2017, 07:17 PM   #1
tmontague
tmontague's Avatar
Most likely your valve cover gasket. Oil coming from up top then leaking down through threads. Valve stem seals typically cause blue smoke after idle due to the higher vacuum at idle iirc. Stem seals also are not known to go on the 1nz.
Replace the valve cover gasket and you should be good to go
Old 12-10-2017, 08:14 PM   #2
DevilzMafia
Drives: Toyota Yaris 2007
Thanks bro, I appreciate your advice!
DevilzMafia is offline   Reply With Quote
Mazda to introducting spark plug less engine. junorico24 Off-topic / Other Cars / Everything else Discussions 3 08-19-2017 06:32 PM
Bigger Spark plug? samuraivince Performance Modifications 6 08-05-2014 04:09 PM
Did I overfill my oil? zkay DIY / Maintenance / Service 10 06-20-2012 10:59 AM
spark plug gap Hard_Yaris DIY / Maintenance / Service 2 06-10-2010 05:23 PM
