Old 12-12-2017, 11:30 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Was actually thinking about it. It's actually simpler than what have diagramed. You just need to add a diode just behind the power wire on the front turn signal. Then power it through a NC relay. Then power the relay using the turn signal stock. When you turn on the turn signal it'll power the relay disconnecting that light and blink like normal.
Old 12-12-2017, 02:46 PM   #2
tamrat
Drives: 2009 Yaris, 1994 HiLux Surf
That setup will work (I have only tested it in a simulation though). The problem with that is if the engine is off (hence DRLs off) front blinkers will not work when the key is at the ON position or hazards are being used. Because they can't switch off anything. the bulbs are already off.
The Surf is still here.... But now there is a Yaris next to it!
tamrat is offline   Reply With Quote
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
