Old 12-12-2017, 11:53 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Because I've never hear a valve tic that goes away as the engine heats up.
Old 12-13-2017, 03:58 AM   #2
Freedomage
Freedomage's Avatar
Drives: YARIS 2010 1NR-FE MMT
VVTI engine valf overlap timing is variable so it can be possible tickling before engine heats up. variables: heat, rev, atmospheric pressure etc.
If everything seems under control, you're just not going fast enough.
Freedomage is offline   Reply With Quote
Old 12-13-2017, 05:54 AM   #3
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Thanks freedomage!
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Checking oil in the Yaris jb48 General Yaris / Vitz Discussion 16 09-15-2015 04:15 PM
Oil Return on upper oil pan sub assembly BoostedTRD Forced Induction Forum 6 11-10-2014 10:23 PM
FS: ZAGE oil Pan TURBO YARIS Items for Sale by private party 1 03-07-2014 01:00 PM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
