Old 12-13-2017, 01:11 PM   #1
Originally Posted by Bluevitz-rs View Post
What the heck is all over the side of the car?! You drive through a coal mine?
oil spray (from a can i got here in MI)
Old 12-13-2017, 02:02 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I noticed that the oil based products do not play well with the rubber tape/seal that holds the side skirts on. It tends to make them expand and wrinkle. I try to wipe it off there asap.
Old 12-14-2017, 07:16 AM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
Interesting, because mine is all dry and cracked.
Sent from my SM-G930W8 using Tapatalk
