Old 12-13-2017, 02:02 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
oil spray (from a can i got here in MI)
I noticed that the oil based products do not play well with the rubber tape/seal that holds the side skirts on. It tends to make them expand and wrinkle. I try to wipe it off there asap.
Old 12-14-2017, 07:16 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Interesting, because mine is all dry and cracked.
