Old 12-15-2017, 03:29 PM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
To clarify. What about wiring the Parking lights to come on with igntion. Relay on an ignition wire to feed ground to parking wire on the head light stalk. This is how my parking and fogs light are wired up to come on when car is on. Then use a Parking/turn signal switchback controller, to make the front signals either stay solid (parking light ground) or flashing when it receives the turn signal pulses.
This is exacttly the same as wiring up projector halos, or shrouds. or those switchback LEDs that have both white and amber.
Heck even easier just get a switchback bulb (example):https://www.amazon.com/iJDMTOY-Filam.../dp/B01JSWEX9O
Check out my Build thread:
Old 12-17-2017, 12:30 PM   #2
tamrat
Drives: 2009 Yaris, 1994 HiLux Surf
The thing is I wanted the turn indicators to come on rather than the parking lights. The switchback LED you linked to looks very interesting. I have to find a way to import here though. Is there a version where both lights are amber?
The Surf is still here.... But now there is a Yaris next to it!
tamrat is offline   Reply With Quote
Old 12-17-2017, 06:07 PM   #3
ezhacker1
ezhacker1's Avatar
So you only want the front turn signals to be on. You don't want parking lights (front or back).
Same thing still Switchback relay. Has 3 wires. 1 is Ground / 12v for (parking light, DRL call it what you want) / turn signal.
Then just wire a ignition wire that supplies 12v with key in on position. Or find a fuse location that is 12v with key in ACC / On. That will be your constant amber light. Then also wire the turn signal and it will act as usual.
I'll slap something together on the car to show ya.
Old 12-20-2017, 02:53 AM   #4
tamrat
I tried to find a switchback relay where I live and I couldn't find any. I have to import it, which is easier said than done. The only ones I found are the normal 4 pin relays (SPST) which are Normally Open.
Took measurements at the headlight dimmer switch and there are 2 hot lines that drop to 0V when indicators are being used (black for left and violet for the right). Since they are hot normally, I think I can wire each to a relay and control each side. When blinkers are used the lines fall to 0V,which will open the relay and turn off the DRL characteristics. Then blinkers can blink away like usual.
Tamrat,
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
