Old 12-23-2017, 12:46 PM   #1
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
last summer when replacing the rear brake pads grabbed a little air in the system. The air was removed by pumping . Unscrew the nipple well
I like very much travel
MickZEL is offline   Reply With Quote
Tags
brake, fluid, flush, replace
Replacement time, and brake bolt rubbers question BennyLava DIY / Maintenance / Service 11 08-27-2016 08:26 PM
Brake Fluid Level Drops Slowly xdarkxfirex DIY / Maintenance / Service 5 03-14-2016 10:24 PM
Did you know a different brand of brake fluid will change performance? UberSilver DIY / Maintenance / Service 5 03-05-2013 01:42 PM
Super dot4 brake fluid and dot3 mixable? lh59 DIY / Maintenance / Service 5 07-16-2012 11:28 AM
Brake lines/brake fluid change out jstantherprsn DIY / Maintenance / Service 3 11-02-2010 12:53 PM
