Old 12-31-2017, 06:22 PM   #1
Janviernes
Drives: 06 5door
Remove panel in front of side mirror?
Does anyone know how to remove the panels in front of the side mirrors? Black triangular piece, not part of the door. Picture if it helps: https://imgur.com/a/CgCUT
Janviernes is offline   Reply With Quote
Old 12-31-2017, 07:39 PM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Get a trim tool or wrap a flat head screwdriver blade with tape, insert at seam and pry. They snap in and out.
Old 01-10-2018, 08:35 PM   #3
daddz07
Drives: Yaris 2008
Send a message via Yahoo to daddz07
What if it breaks..
Sent from my SM-J727T using Tapatalk
daddz07 is offline   Reply With Quote
Old 01-01-2018, 01:22 AM   #4
Janviernes
Drives: 06 5door
Awesome, thanks!
Old 01-02-2018, 08:24 AM   #5
Pinchlite
Drives: 2007 yaris HB
Like NYC-SE said as thats how I basically got mine off.
Curious why you need to remove?
Old 01-11-2018, 08:35 AM   #6
Janviernes
Drives: 06 5door
I'm installing some lights in the panels. Might also be running some wires through there instead of the firewall.
Old 01-16-2018, 12:03 PM   #7
Janviernes
Drives: 06 5door
So best not to do this when it's cold or the piece will shatter into several pieces. Ask me how I know :)
Old 01-31-2018, 01:54 PM   #8
Janviernes
Drives: 06 5door
Ok just for future reference, it's not quite a simple pry-off. The top clip is a standard trim clip (white plastic peg type) which can be pried carefully (best not done in cold weather). Two bottom clips are integral and have a plastic bit that needs to be pushed out of the way or they will break.
2008 Toyota Yaris passenger side view mirror change KOOCHO DIY / Maintenance / Service 1 12-01-2012 09:52 PM
Driver Side Mirror - Can This Be Replaced Easily? (Image Attached) Yarismo123 DIY / Maintenance / Service 3 10-06-2012 10:04 AM
Taking out "Deck Trim Side Panel Assembly" from 2007 5-door (for cleaning purposes!) lech7 DIY / Maintenance / Service 3 01-03-2012 08:56 PM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
