Old 12-31-2017, 07:05 PM   #1
knobby bobby
knobby bobby's Avatar
Drives: 2015 Yaris Coupe
I tried the Cree LED Oslamp in my 2015 Yaris and yes there was some slight flickering. The LED headlights are very redundant. The LED lights I bought were 940 watt per pair and they had these motors like fans that would spin to cool down the lights which was not acceptable to me.
The alternator on the Yaris was stressed out from the load and when you switch from low to high beam the lights actually shuts of for a split second because it cant take the amount of power.
This is redundant because LED is low wattage and low voltage but the fans on the LED lights are
what puts such a heavy draw on the system. Yes there was a big improvement in visibility but it wont be at the expense of my alternator. These LED headlights need more R&D to be as efficient as the COB or or SMD LED which dont need motors to run the lights.
IMHO if you want a kick ass bling set of headlights get NOKYA. Get the Artic White 90/100 Halogens. 85 % bright white and 15% blue. They kick ass and will rival the LED headlights.
knobby bobby is offline   Reply With Quote
Old 01-01-2018, 02:30 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Any usable amount of light output from LED will require additional cooling.
Not sure where you found 940w LED for the Yaris. This is crazy load on the stock wiring. Most what we use are 20-50w.
The fan only requires a minimum of power. Typically 0.10A or so at 12v.
Sent from my SM-G930W8 using Tapatalk
Old 01-01-2018, 03:06 PM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
940 Watts is most likely not a true power figure. Many LED headlight globes are quoted as an equivalent to how many watts of halogen lighting would produce the same amount of light output. The ratings for high and low beam are also often added together to produce totally unrealistic figures.
Unfortunately, most of the "replacement" type globes don't produce the same light pattern as regular halogen globes, so a lot of the light output is wasted, or goes to annoying other drivers.
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
Question about projector headlights. bareasabear General Yaris / Vitz Discussion 2 04-22-2011 05:23 PM
Headlights question dutchy999 DIY / Maintenance / Service 12 01-28-2011 07:53 AM
Black Projector Headlights Question ruimond Cosmetic Modifications (Exterior/Interior) 42 09-23-2009 10:19 AM
DIY- Headlights Question DJPaneno DIY / Maintenance / Service 2 10-31-2008 11:43 PM
