![]() Drives: Toyota Yaris 2NZ-FE Join Date: Jan 2018
2007 Yaris engine swap - 2NZ-FE to 1NZ-FE
Hello all. This is my first post. I am fairly new to Toyota. Any help will be appreciated.
Okay, existing 2NZ engine had turned a bearing and 2 conrods came through the crankcase. I would like to replace the entire engine with a 1NZ. Is this possible ? Here in South Africa, we have 2 versions of the Yaris engine, the 1.3 vvti and the 1.5 vvti. I can get the 1.5 for a good price. What I'm afraid of is will my existing gearbox work ? Will the existing ECU work as well ? I have also installed a new clutch kit on the 2NZ before the damage. Will this clutch kit work on the 1NZ ? Will the engine mountings be the same ? Any response would be appreciated. Thank you. |
#2 | |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Thanks. I will be using old ECU just to start car. Thereafter will remap and dyno tune. Is this possible ? The ECU doesn't know that the engine will now be a 1.5.
Everything should work out fine. Those engines are nearly identical and should also share the same sensors.
| 2007 Yaris Engine Swap | tmtab8588 | Performance Modifications | 2 | 12-29-2017 01:32 AM |
| Yaris 2nz engine upgrade | yarisgravel | UK | 0 | 10-28-2015 06:10 AM |
| 03 Yaris 1.0 VVti Engine Swap, URGENT help needed. | philwept_33 | DIY / Maintenance / Service | 1 | 05-15-2009 12:15 PM |
