#1 | |
PowerAmp app http://powerampapp.com/ One disclaimer... If one of these units fail, they are basically throw away item unless you're electronics-savvy or a willing to find an electronics repair shop willing to take a repair on. The return shipping to China would be cost prohibitive. That said, I have only had one unit fail. It was the touch screen. I still have the unit in my closet and the replacement screen - which is connected with plugs only - is about $40.00. At some point, I'll repair it and have it as a back-up unit for my Sedona. It's a Kia factory fit.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 01-14-2018 at 01:31 PM. |
#2 | |
Enthusiast
Drives: 07 Yaris HB 1.3 (EU) Join Date: Nov 2014
Im trying to find a cheap unit with at least 2GB of RAM though. We're switching to DAB in Greece and my Sony CDX-MP80 doesn't support it, and DAB adapters cost around the same as a headunit.
Cheers, George. |
#3 | |
http://s.aliexpress.com/3yAjy6JN Sent from my SM-G930W8 using Tapatalk |
#4 | |
https://www.aliexpress.com/item/2-Di...ceBeautifyAB=0 However, while waiting for my tracking number, I discovered another unit that I would actually prefer, and it's less expensive. I has no DVD which would make more sense for me as I don't used DVDs but rather MicroSD cards. Also, this unit has DAB+. https://www.aliexpress.com/item/Seic...999.262.iIKV30 DISCLAIMER: I make no assurances that these units are direct plug and play, but I suspect that they are.
