Old 01-17-2018, 01:54 AM   #1
eeeeeh
Drives: Yaris YR 2013
Nice upgrade... side question
Nice work man!. Side question, m.flores.0928, did you put spacers on your wheels? seems it is nice and flush with the panels. if so, what were the front and back thickness?
eeeeeh is offline   Reply With Quote
Old 01-17-2018, 10:22 AM   #2
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
Yea I put spacers on. I have wider tires too. Current tire size is 195/55/15. Front spacer is 25mm and rear is 30mm. They rub now haha
m.flores.0928 is offline   Reply With Quote
Old 01-17-2018, 09:36 PM   #3
eeeeeh
25mm and 30mm? what was your wheel's et? the wheels we get in Aust are standard 14" with bicycle tyre of 175/70. I thought yours was too since it looks like stock wheel covers.
Old 01-17-2018, 09:40 PM   #4
m.flores.0928
Drives: 2014 Yaris
Mine are factory 15 steelies. ET39. Wheel size is 15x5.5 with a 39 offset. Original tire size was 175/65/15
Old 01-19-2018, 02:37 AM   #5
eeeeeh
Darn, you guys get nicer steel wheels as ours in Aust are 14x5 et39 with 175/70/14 shoes. I was actually thinking of getting some old corolla wheels which also has 4x100@54.1 bore, but with 15x5.5 which i can fit better shoes on them... but finding good condition ones might be tough unless i dig through different wreckers and getting the spare wheels from the boot (trunk) or something. :)
Old 01-31-2018, 10:19 PM   #6
Alain93
Drives: Yaris 12
Sorry I'm more interested in your spacers. How can you tie the lug nuts on? Did you change the studs?
Sent from my SM-T530NU using Tapatalk
Alain93 is offline   Reply With Quote
Old 01-31-2018, 10:27 PM   #7
m.flores.0928
Drives: 2014 Yaris
The spacers have studs in them. You bolt up the spacer using the factory studs and lug nuts then the spacer studs stick out to bolt your wheel to
Old 02-01-2018, 09:52 AM   #8
Alain93
Drives: Yaris 12
oh cool! do you have a link for the spacers?
Old 02-01-2018, 10:25 AM   #9
m.flores.0928
Drives: 2014 Yaris
25mm https://www.amazon.com/dp/B01JGPXGPU..._seZCAbPA2T2PJ
30mm https://www.amazon.com/dp/B01LC14W40..._CfZCAbBNEWN42
Old 02-01-2018, 10:36 AM   #10
Alain93
Drives: Yaris 12
Thanks
HELP needed for carputer project: Powered USB hub install Astroman In Car Entertainment + Electronics (audio / video / alarm) 15 11-01-2010 05:18 PM
LED Install Problem (Tails) Betrivent Cosmetic Modifications (Exterior/Interior) 42 10-29-2010 03:49 AM
