Old 01-19-2018, 09:19 AM   #1
tamrat
Drives: 2009 Yaris, 1994 HiLux Surf
Originally Posted by ezhacker1 View Post
If its just using relays then i think this will be it:
You need the pulsed signal in the engine bay to be a constant so it can trigger another relay
85 - Output from above relay
86 - Ground
30 - 12v
87a -Turn signal 12v
Now unless the (pulse to constant relay) is sending pixies to the 2nd relay. You will have constant 12v to the front turn signal.
I don't know why this didn't work the first time (in simulation). But there is good news. With the comment on switchbacks and this diagram and also help from a lot of people, I have a fully working system now. I mocked it up on the bench and its perfect. Flawless.
Here is the wiring diagram and component specs:
The 6600uF capacitor holds plenty enough charge to keep the relay energized for about 1.6 seconds. This duration is long enough when compared to the period of the pulses from the indicator light wires.
I'll have already started installing the system. I have laid out wires and where every thing goes. I just need waterproof containers for the circuits and also a switch that will fit one of the empty slots around the AUX port. And its a bummer that the Yaris doesn't have a gromet in the driver's side (LHD). I had to pull it though the passenger side.
I'll put up pictures once I'm done.
Tamrat,
The Surf is still here.... But now there is a Yaris next to it!
tamrat is offline   Reply With Quote
Old 09-11-2023, 12:45 AM   #2
Kasbien
Kasbien's Avatar
Drives: 07 Sedan (AT)
Tamrat,
Thread revival.
Did you ever get this working in your actual car?
Kasbien is offline   Reply With Quote
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
