Old 01-19-2018, 07:49 PM   #1
ex-x-fire
Use an open end wrench to determine the size, if a 12mm open end fits snuggly over the threaded portion, that's your size. As for pitch, do you have any thread files?
If you go to a place like Fastenal they should be able to figure it all out.
Old 01-19-2018, 10:00 PM   #2
XXXXX
Drives: 2008 Yaris Hatch
Thanks for the ideas. I don't have any thread files or gauges but I do have digital calipers.
I put my calipers on it and it came in at 11.75mm on the major diameter of the threads. Thread pitch per the calipers is 1.25mm. (EDIT)
So looks like a 12mm Fine bolt.
The nut is 17mm, but the bolt head is missing. Probably the same?
This was a flange bolt and nut. Is the size of the hex head size going to correspond to a certain shank and flange diameter? Rather than using a washer on either end I'd like to keep the same style.
Also, this isn't a nylock nut nor serrated. It has six stamped dots around the circumference of the flange. Distorted thread?
Finally there's the length. I guess any old length would do as long as it's long enough. I'd like the un-threaded portion to make it past the shear point of the bolted connection.
It occurred to me to use any old grade 8 bolt that would closely fit, but If someone had access to the OEM spec of course that's preferable.
It's gotta be in some kind of technical/service manual somewhere?
XXXXX is offline   Reply With Quote
steering Rack ends replacement how to Kitt DIY / Maintenance / Service 13 12-29-2018 02:34 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Steering wander, adjusting EPS assist Snubba Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-22-2012 05:39 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
Upgrade Steering rack bushings?? aeipee13 Performance Modifications 1 07-14-2009 02:17 PM
