smoking alternator terminal-to-cable-connector connection Yaris
What would OP's smoking alternator terminal-to-cable-connector connection do to the working parts of the alternator?
--Locally heat up the terminal post and what is touching it. --Make alternator work full power all the time to maintain desired output voltage to system. (OP's voltage drop measurements suggest this.) I don't see that either of these effects would have necessarily hurt the alternator...do think I'll double-check that connection. |
#2 | |
I removed the alternator and disassembled the back cap of it (where the regulator and brushes are housed) and found some corrosion. took it all apart, cleaned it up and now getting a healthy voltage. I have found a junkyard alternator that I have on my bench for the next time it acts up. the heat could have possibly damaged the regulator but in this case it seems fine.
| Smoking Ban? Drinking Ban! | chrisj | Off-topic / Other Cars / Everything else Discussions | 47 | 10-23-2010 01:38 PM |
| Quitting smoking.... | coffiend | Off-topic / Other Cars / Everything else Discussions | 26 | 08-20-2010 01:28 AM |
| quit smoking how long does it take to .... | marcus | Off-topic / Other Cars / Everything else Discussions | 14 | 11-12-2008 08:20 PM |
| Buy a Yaris, Quit Smoking | Typer73 | Off-topic / Other Cars / Everything else Discussions | 36 | 05-02-2007 07:24 PM |
