Old 02-10-2018, 09:37 AM   #1
tmontague
tmontague's Avatar
The warning is misleading as it pertain technically to the rubber mount/isolator as that is what holds the spring compressed. If you remove that one without a spring compressor then BAM you could get a spring to the face.
In this case the upper piece isn't holding the spring under tension so it is fine to remove
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
2007 and up Yaris Sedan S McDizzle New YARIS Purchase Forum 3 12-03-2009 01:42 PM
