Old 02-13-2018, 04:15 PM   #1
atomic_hoji
Drives: 2018 Yaris SE 5MT
Not familiar with 2nd gens so much, but just to throw ideas out - which maybe you've already thought of...
Do you know if the wiring harness for your RS has the connections available (just unused)? Assuming steering wheel controls were available in one of the models in 2006.. If so, you could find a oem steering wheel at a wrecker and swap. If not, what about swapping to a later model steering column from a wrecker making sure you grab the wire harness bits; grab as much as possible, wire the rest to the new unit?
Anything that sticks out off the wheel seems like a PITA waiting to happen, but also understand there's a cost and effort benefit ratio of aftermarket vs. parts hunting, dash teardown, and wiring to get oem feel. lol
Good luck with whichever path you take; keep us posted.
-- Adam
atomic_hoji is offline   Reply With Quote
Old 02-14-2018, 05:37 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
-- Adam
Yes, I did think about a wheel swap but currently have no idea if the wiring is present. I skimmed a CTScott post and if I recall correctly, wiring can be added. Just not sure I want to tackle a job of such magnitude given that I'm already facing a large audio system install in the spring along with a dash pad replacement. I agree that things being stuck to the wheel could get in the way. That said, I was in a car recently - don't recall the model - and it had buttons on the back of the wheel. They were easy to operate and fairly intuitive.
Thanks!
Old 02-21-2018, 02:48 AM   #3
vivalaflam
Enthusiast
vivalaflam's Avatar
Drives: 07 Yaris HB 1.3 (EU)
Most probably a Citroën or a Peugeot. That little stalk behind the wheel also includes the cruise control!
Cheers, George.
vivalaflam is offline   Reply With Quote
Old 02-21-2018, 05:00 AM   #4
Whiplash
Drives: 2009 Yaris 4DR
We don't have those here. But I know dodge caravans have the buttons on the back, so probably dodge or FCA models.
Whiplash is offline   Reply With Quote
Old 02-21-2018, 05:45 AM   #5
06YarisRS
That's it! I'm pretty sure it was the 2017 Dodge Grand Caravan we had when our Sedona was in the collision shop.
Trouble codes when installing a aftermarket steering wheel. ttr125fan09 DIY / Maintenance / Service 2 10-12-2014 08:26 PM
Adding steering wheel audio control to MK1 P2 Kennymen In Car Entertainment + Electronics (audio / video / alarm) 6 08-31-2013 08:07 PM
Steering wheel audio controls? vodkalush In Car Entertainment + Electronics (audio / video / alarm) 14 09-13-2006 11:17 PM
