Old 02-17-2018, 10:41 AM   #1
MadMax
MadMax's Avatar
I have an 08 that makes a scraping noise on the driver's side when I got over hard bumps at speed. I suspect it's part of the fender lining come loose, but any other ideas?
Cheers! M2
Old 02-20-2018, 09:30 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Cheers! M2
I think that a loose fender liner should
be relatively easy to diagnose but without
further description it would be difficult to say
for certain what your scraping issue is. I'd
check end links though.
