![]() ![]() Drives: Yaris 2008 Sedan Join Date: Nov 2010
I went after my front brake maintenance today.
Found the grease inside the sliding pins in nasty goop stage, cleaned everything up and re-greased with hi-temp brake grease. The bushings on the bottom slide pins had expanded too much to slide back into place, so I had to replace them. Replaced the boot bushings because they came in a kit from O'reily's. Found one of my front shock insulators was all torn up. and my bleeder caps were thoroughly cracks, so I'll be ordering those parts and replacing them. One of the bottom slide pins looked very corroded while the rest just seem to have some wear patches, I think I'll replace the corroded looking one. zoidberg444, I have the WP and spark plug inspection on my list for tomorrow, today dragged out more than expected because I had to wait on parts, and it'd been a while since I had done the slide pins, so was feeling overwhelmed with the decisions of how much grease to use. lol I have a Battery charger BESTEK 600A Peak 10000mA, it was buried in my "have:" list in OP. I have spare bulbs for head and tail lights already too. Looks like I should definitely get a fuel container then, maybe a 2 gallon (~7.6L), should get me max 80 miles (129km). Good idea on the zip ties, although, I feel like I will be carrying too much stuff now, haha, but it's a long trip. Getting paranoid, but I know that doing such a huge amount of driving in such a short amount of time will statistically increase my chances of encountering hazards. I'm actually planning to document quite a bit of the trip. I just got an essential phone with a 360 camera attachment, so I plan to do some pictures and video in that format. I also want to do some time lapsing of my dash cam recordings. May even start a youtube channel, but not too sure on that just yet. We'll see how it flows once, I start. Dodge Aries K, Rockford, IL isn't much of a detour from my current route through Illinois. I'll send you a message when I get closer. I should be there about 37 days after I start my trip according to my route estimate. Brosin, I'll actually be visiting a friend in New Jersey, haven't checked where he is just yet, but I'll definitely let you know if you're nearby. HAha, guess they had not seen the mythbusters video where they tried to drive a fast low car under the legs of a deer/moose? Thanks again for all the support and great ideas! EDIT: Forgot to mention I'm using furkot to map out my road trip. It's actually pretty neat and you can set parameters for max distance driven per day or max hours. |
#2 | |
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
Yeah. Normally when i go on a trip and I'm camping my car gets a bit... full. The Yaris takes it like a champ though!
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
zoidberg444,
haha, that's fully packed! How do you like the electric cooler? That's another item on my list, I've been debating. However, I think I may go with the $300 coolers since I'm not going to be driving 24/7 nor may be around outlets often enough.I did my brake fluid change about 3 years ago at 160k miles, and had never done it before that, so I think it will be fine. However, I think I do need to top it up. I noticed it had moved down a bit. I was given a verbal warning on the mountains because I was going 5MPH over the limit, and "braking too much." I was in second gear, which tops out around 30MPH, limit was 25MPH. So I kept lightly tapping the brakes to try and stay below. Didn't care to argue since it was just a warning. If I had gone into 1st I'd be stuck at 15MPH -__- |
#4 | |
I read the recommended service interval for brake fluid is 2 years. There is a little gadget you can get that checks the moisture content in the fluid and tells you if its time i change it. I did mine in 2016. I'll probably do it again this year for my winter service.
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback Join Date: Jul 2016
Awesome, sounds good. You can see all the cool abandoned buildings here hahaha.
-Karl the Uber/Lyft Driver |
| 999,435 Miles On My 09 Yaris! The Big M Any Day Now! | bronsin | General Yaris / Vitz Discussion | 19 | 03-07-2015 05:11 PM |
| Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c | Yar Is Word | Third Gen Yaris General Discussion | 27 | 09-06-2012 11:37 PM |
| Yaris Off Road??? | Rutherfordman | General Yaris / Vitz Discussion | 18 | 02-26-2010 10:13 PM |
