Old 03-01-2018, 07:41 PM   #1
tmontague
tmontague's Avatar
I do agree with the OP on this thread. The Yaris is a purpose built machine, performance is last on that list. The main focus being low end torque to keep the revs low and fuel economy high as a grocery getter. It does this well but at the cost of top end, and it leads to a dull drive.
You can slap all of the bolt ons you want to a 1nz but unless you do a full on build with a custom tune like Jason has, it will still fall flat on its face above 5.5k rpm. I had full bolt ons on my 1nz I/H/E plus golden eagle intake manifold and above 5.5k rpm it stopped pulling hard.
This is where the 2zr comes in, much better area under the curve and with dual vvt-i and pulls much harder to redline.
Old 03-01-2018, 07:45 PM   #2
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
Someday I'll get that 2ZR swap going.
m.flores.0928 is offline   Reply With Quote
Old 03-01-2018, 08:23 PM   #3
tmontague
tmontague's Avatar
If you look at the whp numbers Tom has posted on his build you'll realize with mild bolt ons the 2zr can net you the equivalent of a 155-165 hp factory car all with the reliability of an Toyota and on a very light chassis
You look at cars advertised at 200 hp such as the gt86 but are only posting 165 whp on a dyno...
Old 03-01-2018, 09:01 PM   #4
m.flores.0928
Drives: 2014 Yaris
Well they all advertise crank hp and not wheel hp. Of course 200 crank hp will throw down 165 hp on a (chassis) dyno
1nzfe, boring, slow
Replacing an 1NZFE by another 1NZFE ? jenfre DIY / Maintenance / Service 6 02-22-2021 12:38 AM
Engine rebuild or engine change? big dilemma.... Elwe2k DIY / Maintenance / Service 28 02-02-2017 11:21 PM
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-13-2010 12:47 AM
1NZFE engine illustration Parmas DIY / Maintenance / Service 5 07-24-2009 03:35 PM
