Old 03-22-2018, 01:38 AM   #1
komichal
Buy yourself a mixture with water 1:1 of G12+ (pink one) and pour it in. The brand is not that important.
For a full flush the guys here would recommend to go only with OEM Toyota coolant but if you just need to add a bit then you can use anything. I did a full flush recently and used Sheron as the Toyota stuff costs a fortune while there is no measurable difference.
Old 03-22-2018, 05:02 AM   #2
vaironl
vaironl's Avatar
Drives: 2010 Yaris 3 door, manual tran
Thank you for the advice, gonna get it ASAP! I did notice the Toyota coolant will cost a pretty penny!
vaironl is offline   Reply With Quote
Coolant flush procedure? BennyLava DIY / Maintenance / Service 24 11-20-2014 05:11 AM
Help ASAP!!!! low coolant indicator MeggiemobileSFLA DIY / Maintenance / Service 29 08-03-2013 01:09 AM
Query re: low level coolant indicator tracey540 General Yaris / Vitz Discussion 2 05-12-2010 06:01 PM
