Old 03-25-2018, 10:29 PM   #1
grilled cheeseus
Drives: 2007 3 door 5MT
Thumbs up
Just replaced the original gasket on my 2007 hatchback with 120k miles and 10 salty upstate NY winters. :D
Photos
Before trying to loosen the flange bolts, I used a MAP-Pro torch ($50 at the Homeless Despot) to get the nuts red-hot. You can hit the nuts with a torch from the engine bay -- I unclipped a wiring harness to make more room to work. Watch your aim -- there are O2 sensor wires just above the flange on the driver's side.
After heating each nut, I crawled underneath, hammered a socket with long extension onto the rusty bolt head, and carefully(!) applied torque. Got them both loose with no fuss, and the rest of the job was easy. I used new bolts but kept the original captive nuts.
The replacement gasket I used was a Walker 31619. May be a little different than OEM gasket size (definitely different material), but it seems to make a good seal. Car sounds much quieter now and less rough when accelerating. I'm probably breathing cleaner cabin air too.
grilled cheeseus is offline   Reply With Quote
Old 12-07-2018, 02:37 PM   #2
myfirstyota
3 Yaris and counting..
Has never failed me. I've done 3 of these gaskets now. Gasket from Toyota (canada) $50-60, I think the bolts are $7 and change each.
Newbie with an exhaust leak on his '06 Yaris ToYarta DIY / Maintenance / Service 49 01-03-2019 12:50 PM
My Echo Exhaust Leak in Front ? frank2005 General Yaris / Vitz Discussion 8 08-02-2017 08:52 PM
Enkei's and Dunlops + Medalion Touring Exhaust 2manywheels Items for Sale by private party 40 04-04-2011 05:01 PM
