Old 03-29-2018, 10:21 AM   #4
tmontague
tmontague's Avatar
As ex x fire stated your shifter cable likely snapped. It can be fixed by yourself with some hardware jimmy'd to fix the cable but if you haven't much experience working on a car then your best bet is to have a mechanic replace the cable.
Spraying the gear shift bushing with lube can help avoid this issue down the road.
To check it, have someone sit in the car and shift it into different gears. You look at the front of the transmission and see if the cable is engaging the metal level on the transmission or nkt
Tags
automatic, problem, repair, yaris
Yaris hybrid '13 when doing 60 revs high - expect it to switch gear funky2nite General Yaris / Vitz Discussion 8 04-18-2017 04:20 PM
