Old 04-10-2018, 08:33 PM   #1
B.B._07
Drives: 07 5dr
It's not traction control, the Yaris doesn't have it and if it did you always get the indicator light coming on in the dash when it's activated. Stability control wan't made mandatory in all new cars in the US until 2012.
Are you holding a cut wire in the video or is it a small hose? I'd suspect you have some frayed wiring in that harness somewhere that is shorting out for a moment when you hit a bump in the road or pull on the harness. Look for obvious damage first like, get a good light and mirror if you need it. After that take a close look at the connectors on both end of that harness for damage or corrosion.
Old 04-11-2018, 11:38 AM   #2
Cigar_Maverick
Cigar_Maverick's Avatar
Drives: 2007 Yaris Hatchback
Cut wire. From something the previous owner had hooked up. I'll take it lose this weekend and make sure the original wire is OK. I don't know what it was from. Might just be one of those blue wire splicers behind where you can't see. No idea what it was for originally. But been that way for the two years I've owned it.
I'll take the split corrugation lose this weekend and give it a gander. Really intermittent. No problems on the 35 mile drive this morning.
Cigar_Maverick is offline   Reply With Quote
fuel delivery, ignition, loose wire, power loss
2007 Toyota Yaris Hatchback - 5-Speed Manual truebreakerz Cars for Sale by private party 23 09-17-2009 09:29 PM
