Pics never show the flaws, but that looks real good.
Thanks. Well, it's going to get another sanding and repaint. I took it out into the sunlight and it looks ok, but I could also see a bit of light shining through. I have a pretty good basecoat though now. I'll post up pics of the finished product.
After that, it's the front lip. That, I'll install first and then paint it on the car. I doubt that this paint would handle any amount of flex. The above said, if I'm not satisfied with the overall look of the car, I have another possible plan. There is a fellow locally with an autobody/collision shop. I am going to ask him to do an estimate on painting the back of the car. I've seen some of his blending work from all angles and the guy is a pro - virtually impossible to see his blending. The other option is a total repaint, except the door jambs, engine bay under hood, tailgate, inside of doors etc. I had spoken with him before and he quoted me around $350 - $400.00 to do the back end. If I repaired the tiny dings and sanded out the light scratches and he was willing to seal, base coat and clear for around $1K, I may do it. He is open to painting cars that other non-professionals have done minor body work on.
![]() ![]() ![]() Drives: 1987 Silverado Join Date: Jan 2010
When you polished out the headlights, what grit of sand paper did you use?
Also, is the the exact polish you buffed them with afterwards? https://www.autogeek.net/klashiggloss.html |
#4 | |
Thinking about doing yours? Klasse HGSG is the product I use exclusively for my car's paint. I have been using it for years and although I haven't tried many other sealants, it is amazingly durable/long-lasting and a few layers creates the most gloss candy-like and slick coating. And, to boot, a $30.00 jug (large jug) will last years! My cars get 4 - 5 coats a year and application is quick. If you want the best method, IMO, follow the link below. I do my headlights every time I do the paint too. I don't use Klasse All In One (AIO) as my paint is pretty clean usually anyway. https://www.detailedimage.com/Ask-a-...de-and-review/
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 04-19-2018 at 09:28 PM. |
This look better? I think the extra effort will be worth it. I resanded, repainted and re-cleared. Clearcoat is nice and thick, so should be easy to polish out the orange peel and achieve a high gloss.
Some day I'd like to invest in some actual automotive painting equipment and learn how to properly paint a car. ![]() ![]()
I thought it looked good earlier. Any flaws then were really only visible to your eye. Camera doesn't pic them up. Just like taking a pic of my front bumper. Looks fantastic in pictures, naked eye sees something that looks to have seen the business end of a 12 gauge.
#7 | |
| Is a 2006 Yaris coupe different from a 2007 Yaris coupe? | fuzzybabybunny | General Yaris / Vitz Discussion | 0 | 02-25-2016 07:09 PM |
| Consumer Reports on the 2006 Echo | BLKHILLSGUY | Third Gen Yaris General Discussion | 5 | 06-26-2015 05:58 AM |
| Install kit for 2006 hatchback | milothicus | In Car Entertainment + Electronics (audio / video / alarm) | 9 | 04-21-2009 07:49 PM |
