Old 04-22-2018, 12:27 PM   #1
Mad$
Drives: Yaris
Can it fit?? 17 - 7.5 ET 35
Hi guys. I Got a third generation Yaris and i looking for a new set wheel and i have found KW series s11, but my problem is that there is 7.5 width with ET 35,
My question is Will it fit in the front ??
Hope some one out there Can help me😃😃
Mad$ is offline   Reply With Quote
Old 04-22-2018, 01:52 PM   #2
Cool wheel, tho I personally don't care for directional spokes. Will it fit? Barely. You'd probably have to do a stretched tire.
Old 04-22-2018, 11:33 PM   #3
SirDigby
Drives: 2007 yaris 3 door
it will fit fine. use the calculator
https://tiresize.com/wheel-offset-calculator/
Old 04-23-2018, 05:42 AM   #4
tmontague
tmontague's Avatar
If you're not lowered then it should fit fine. If you're lowered you will probably need to run some negative camber to avoid rubbing
Old 04-23-2018, 02:51 PM   #5
Mad$
Drives: Yaris
I not sure how to use the calculator, 😔
I have lowered a little bit, not so much. I Will buy the and hope it Will fit.
Thanks a lot guys 😃
Old 04-23-2018, 08:51 PM   #6
SirDigby
Thanks a lot guys 😃
it's not hard at all. it's simple:
-stock wheel/tire size is 185/60/15 offset +45
-enter in those numbers into their respective locations
-enter the new size; you didn't specify, i guess, 205/45/17 offset +35
beep-bop-beep-bo-beep
the tire sticks out .8 inches (20mm) from stock. the inner sidewall is .01 inches (.25mm) closer to the engine bay. the tire is taller, .3 inches (7.6mm) closer to the top of the wheel well. if you go with a 195/45/17, your stick-out drops to .59 inches (15mm)
Old 04-23-2018, 02:53 PM   #7
Be sure to update here if you do get them. Give us more info on what happens when people go to the limits of wheel width and offsets. Like I said, I believe you will be borderline.
That calculator doesn't really help when it comes to figuring out if you will buzz the wheel wells if you bottom out the suspension. You probably will experience this in the rear end.
Old 04-24-2018, 06:22 PM   #8
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
wavy
https://www.willtheyfit.com/
use the stock yaris oem rims specs and stuff.
input
theres a guestimate.
DarkShadowFox is offline   Reply With Quote
Test Fit $50 Or LED Tail lights winson California 6 01-05-2010 08:31 PM
Sorry guys, I bought the Fit. john21031 Off-topic / Other Cars / Everything else Discussions 39 12-29-2009 03:53 PM
Why does everyone compare the Yaris vs Fit... b_hickman11 General Yaris / Vitz Discussion 71 03-03-2009 09:57 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
Will honda fit rims fit on a yaris. Meaning are the hubs the same bore? YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 12-24-2008 03:09 PM
