Old 04-22-2018, 06:31 PM   #1
Jeff Lange
Drives: 11 GSE21, 86 AE86
Originally Posted by praivo View Post
The ECU does NOT care about the actual AFR - all it wants to do is to reach lambda=1. Lambda is lambda, regardless of fuel. So the only thing I need is to increase the flow so that the ECU can its reach target lambda without having to increase the injector pulse width too much and freaking out, and the least obvious way of doing that is by using bigger injectors that spray more fuel.
Is your 1SZ not equipped with a wideband O2 (A/F) sensor?
Jeff
2011 Lexus IS350 6MT F-Sport with LSD
1986 Toyota Corolla GT-S Supercharged with TRD Stuff
2005 Toyota Yaris RS 5MT Short Track Car
Jeff Lange is offline   Reply With Quote
Old 04-22-2018, 07:10 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Jeff
Pretty sure a 1SZ from 2000, only has a basic O2 sensor.
1zz injectors suit the S/C just fine LtNoogie Forced Induction Forum 51 04-30-2016 10:11 AM
Genuine Denso 335cc Injectors Set of 4 Flow Tested fnkngrv Items for Sale by private party 1 05-18-2014 12:47 PM
Stock Injectors = Maybe? Big NO? maxthehax Forced Induction Forum 3 12-10-2012 05:29 PM
Technical question about bigger injectors LtNoogie Forced Induction Forum 1 08-14-2009 03:34 PM
bigger injectors? xxae07xx Performance Modifications 6 12-31-2008 05:04 PM
