it can, but if you look at the little covers underneath; there are brackets in there that can be installed by drilling a hole and using included plastic inserts. (i used metal threaded inserts and a bolt) also, i believe there are 2 plastic arrow clips on the spoiler that will have to be removed if you don't drill alignment holes. (if installed from factory)
#2 | |
![]() ![]() Drives: 2015 yaris hatchback Join Date: Jan 2018
Factory installed would be drilled. I'm saying, for that particular spoiler, 3M tape would do the job. It's a scary thing to take a drill to your body panels.
im just a little lost because the spoiler in the pic is a factory toyota oem part.
you don't have to. the covers clip into place. they install the bracket for safety, but the drilling is easy;
-hand tighten nuts on bracket, spoiler side -hold spoiler in place where it is live forever -mark holes with marker -remove spoiler and drill holes -put tape on the drill bit at 5mm if you are scared of drilling too deep. -use touch up paint around bare metal it's super easy to do, but if you use just the tape, make sure to use some really good stuff, like VHB 3m |
| DIY Sedan Spoiler Install | Kaotic Lazagna | DIY / Maintenance / Service | 36 | 01-19-2020 11:35 PM |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| DIY Hatchback Spoiler Install | skootdog | Cosmetic Modifications (Exterior/Interior) | 29 | 06-14-2016 04:44 PM |
| What would the labor costs be to install a spoiler? | JerseyJeff84 | Cosmetic Modifications (Exterior/Interior) | 11 | 08-22-2010 07:24 PM |
| DIY Sedan Spoiler Install Interest? | Kaotic Lazagna | DIY / Maintenance / Service | 28 | 09-11-2007 11:02 PM |
