Old 04-25-2018, 03:26 PM   #1
Beauty. Supplied studs appear to be of a length that will not cause issues when it comes to putting them in there.
Old 04-25-2018, 03:37 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
So awesome. Hang tight. I'm going to add a pic of the studs to give you a better look.
Pic... Can you confirm WeeYari, that these will indeed go in without removing the hub? Of course, I won't hold it against you if I can't get them in due to my mechanical ineptitude, LOL! Not sure what the longer greyish bolts on the right are for.
Old 04-25-2018, 03:38 PM   #3
Don't need one. Can clearly see they are a good length.
Old 04-25-2018, 03:55 PM   #4
06YarisRS
So, if all goes as planned, I'll have some before and after pics tomorrow. Thanks!
Wheel hub spacers be warned! tmontague Performance Modifications 17 07-07-2016 09:56 PM
PG Hub spacers group buy Vitz_Q8 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 45 11-15-2015 02:10 AM
FS: Hub Spacers (R) /Wheel Spacers (F). Come with extended bolts. Betrivent Items for Sale by private party 1 06-26-2015 10:41 PM
Wheel spacers walkthrough :) Lars Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 06-05-2014 08:49 AM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 07:10 PM
