Old 04-27-2018, 04:41 PM   #1
pb2k
Drives: 07 Yaris HB
Hey @ David C, how hard was it to convert the parking lights to DRL? I'm in the same situation where I installed new LEDs and pulled my DRL relay. Any pictures or links to good information would be appreciated.
Right now I have some Sylvania 0.7W 2825 LED's but I think I'll need to move those to the side markers and get some T10s closer to 3W for them to be bright enough to not draw any unnecessary attention from the constabulary. What are you using?
pb2k is offline   Reply With Quote
Old 04-27-2018, 10:13 PM   #2
David C
Drives: White '07 3dr LB
I'm using the Phillips interior Vision 194 bulbs in the parking lights, I tap a 12v ignition powered from pin 3 of the alternator connector, since the led draws so little, the 10A GAUGE circuit that this wire is being fed from won't mind. Then I used a nearby bolt to ground to frame. If I remember, pin 3 is the green wire (at least on my own car).
I did grab a pair of parking light connectors from the scrap yard so I wouldn't have to hack into the car factory harness.
David C is offline   Reply With Quote
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
LED License plate lights for Yaris Sedan YarisSedan DIY / Maintenance / Service 6 04-09-2013 04:05 PM
Sponsors List RogueYaris Sponsors Classifieds Area 14 01-05-2013 10:23 PM
Custron T1062TYT Review (Long) mr.steevo In Car Entertainment + Electronics (audio / video / alarm) 1 11-24-2011 02:13 PM
Solar powered High Bright LED lights replacing the fog lights alan1828 Canada 10 05-14-2010 12:34 AM
