Old 04-27-2018, 11:58 PM   #1
B.B._07
Drives: 07 5dr
Originally Posted by alanwagen View Post
These cars are very picky about a belts. You should of got a Toyota belt and your squeal will go away. There is something unique about the Toyota belts.
These cars aren't picky about the belts, they're picky about having enough tension on them. There's nothing special about the Toyota belt, Toyota just buys the belts from most likely one of the big 3 belt manufactures (Bando, Gates, and Continental) and has them label them differently.
Old 05-02-2018, 03:29 AM   #2
RMcG
Drives: Yaris manufactured after 2007
Thanks B.B.,
Do you have more information to back up what you say that there is no difference between Toyota belts and belts made by Bando, Gates and Contintental?
What about the problem of over-tightening adversely affecting the alternator (or other) bearings, do you have any comments?
A friend thinks that the Toyota belts maybe different in terms of the actual dimensions of the ribs and grooves on the inner surface of the belt.
He also thinks that the theory about the slow key turning allowing the onbaord computer to adjust is bogus. He thinks that turning the key faster and harder just makes for a better contact and more amps through the starter motor and thus more initial speed/load on the belt, hence the squeel.
Any comments by you or others would be appreciated.
R.
RMcG is offline   Reply With Quote
Tags
belt, squeeling
Belt Squeeling. alweasel General Yaris / Vitz Discussion 4 09-27-2019 12:07 PM
Oil change shop says alternator belt is cracked RMcG DIY / Maintenance / Service 19 05-02-2018 08:38 AM
Blitz Supercharger Belt Slip @ Higher RPM? Freestylin Forced Induction Forum 20 09-06-2017 08:32 AM
Belt Squeeling like a Mofo gumby002 DIY / Maintenance / Service 7 09-10-2016 06:38 PM
DIY how to change you belt in 10 minutes without breaking VVTI solenoid YarisSedan DIY / Maintenance / Service 2 04-12-2013 11:41 AM
