Old 05-06-2018, 01:47 AM   #1
white89gt
Drives: 07 Yaris Hatch
Trans slams at WOT
I have an odd problem with my Yaris. About 50% of the time, when I floor it, the trans will downshift, then it sounds like it hits a neutral condition, then slams back into gear, and will repeat this cycle until you let off the accelerator. Other than this, the car, motor, and trans all work as they normally should.
Is this a common issue on these? Anyone experience this, or hear of this happening, and any clue what the fix is? Drive by wire is a new animal to me. I am assuming it has something to do with the TPS, or whatever Toyota uses there.
Any help is much appreciated!
white89gt is offline   Reply With Quote
The auto trans > manual trans conversion guide ArmstrongRacing Performance Modifications 43 10-23-2022 04:33 PM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 12:56 PM
Dropping the tans in a 2zr swapped Vios tmontague Performance Modifications 2 04-29-2017 08:29 PM
Effects of too much trans fluid in the case? (auto trans) detroiter General Yaris / Vitz Discussion 5 02-25-2009 12:08 AM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 11:57 PM
