Old 05-08-2018, 10:32 PM   #1
BlackTy
Drives: 2008 Yaris sedan
Is there a way I can diagnose the problem by myself? I fear paying a shop to take a look at the problem will cost a lot of money too.
BlackTy is offline   Reply With Quote
Old 05-09-2018, 02:16 PM   #2
Make some phone calls. What do you consider 'a lot of money'? I paid $115 for the diagnostic I had done, which included the aforementioned smoke test. At some point here, your time has got to be considered of some value.
Unless it was hanging loose, the gas cap would have thrown a P0456 (minor leak).
Old 05-09-2018, 09:43 PM   #3
also, no one in canada uses the number of km traveled on a liter of gasoline. its L/100km.
8.3L/100km isnt terrible for city driving in a slushbox. that your previous car did 6.7L/100km is great. but a 95 civic is a bit lighter on smaller, narrower tires. all things contribute to better fuel economy.
i used to commute in my echo 110km to work 3 days a week and going from a 175-65-14 to a 195-50-15 changed my FE by almost 1L/100km (5.9 to 6.8 or so)
Old 06-22-2022, 01:35 AM   #4
Vyaris07
Vyaris
Drives: Yaris-2007 1.5L Auto 3doors
Wink P0441 code fix How-to
My Yaris 2007 got issue with P0441 code, read this forum and figured out the EVAP canister rubber is degraded, then :
1. Remove gently the canister out.
2. Wrap each very-end with office 1/2" wide clear-tape about 3-4 turns.
3. Re-insert the canister pipe back gently.
4. Bought two spring clamp 3/8" size, put on at least 1/4" from each end.
5. Run engine and turn on the code reader, clear the P0441.
6. Check the gas cap for clean-up the O-ring seal, then tied it up with 1-2 clicks.
After running idle for 5 min, read the code again, as result, no more P0441!
DIY is easy as this task!
Vyaris07 is offline   Reply With Quote
EVAP leak detected? eepp DIY / Maintenance / Service 7 01-29-2018 12:42 AM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
