Old 05-19-2018, 12:52 AM   #1
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Originally Posted by JDJanitor View Post
I was at Walmart today getting oil, I bought the 530 supertech full synthetic and a Fram Ultra filter that they say can go 20,000 miles between filter changes. I would hope to be able to go at least 7,000 or 7500 miles on an oil change I'll see what it looks like as time goes on.
It would be cool to be able to leave the filter and for two changes because I will go at least 15,000 miles a year but I am not sure I trust that filter would be good
It seems that as long as you change the oil and don't let it get old and sludgy your car should last a long time from what I've read
Sent from my moto x4 using Tapatalk
I have used Supertech Full Synthetic 5W-30 in my Yaris. It is good quality oil and will do 7500 miles no problem. The Fram Ultra is probably the best quality filter out there and can definitely be used for 2 oil changes. For the record I do not use the Ultra but only because I'm a cheap bastard who bought a bunch of different high quality filters at closeout prices at Walmart.
If you don't know about BITOG take a look. There is more information about oil there than you would ever need to know.
https://www.bobistheoilguy.com/forum.../forum_summary
Old 05-19-2018, 01:11 AM   #2
BennyLava
Drives: 1987 Silverado
After spending a good deal of time over at bobistheoilguy, trying to get to the bottom of the oil mystery, The best oils are:
1. Redline
2. Amsoil
3. Royal Purple.
In that order. Everything else competes for lousy slots that are somewhat distant from these top 3. For a filter, the Royal Purple brand oil filter is top notch. IIRC it filters down to 3 microns. Not a whole lot is going to get past that. Due to the other 2 costing more, I have always ran Royal Purple in our Yaris and it has 200k on it. With royal purple filters. I run the oil for 7500 miles before changing it.
Old 05-19-2018, 01:04 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
1. Redline
2. Amsoil
3. Royal Purple.
I've always ran RP with OEM filter. Due to lack of availability, I switched a couple years ago to AmsOil, and also tried their EK filters and seems to be great.
Anyways, I went back to OEM filters for cost reason.
Sent from my ONE A2005 using Tapatalk
Old 05-19-2018, 01:16 AM   #4
JDJanitor
Drives: 2016 yaris
I have spent some time over there. Really a wealth of information!
I will try two oil changes on the filter,aybe I can try to cut it open like they do over at that site.
JDJanitor is offline   Reply With Quote
Fuel filter replacement jaimico DIY / Maintenance / Service 43 03-07-2023 11:05 AM
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Car shuts off when A/C turned on... Howster DIY / Maintenance / Service 33 07-06-2013 05:00 PM
Beware WIX Filter #51394 zkay DIY / Maintenance / Service 19 12-22-2012 12:09 AM
DIY - Cabin air filter location (Belta, Vios, Yaris sedan) Murtaza_murti DIY / Maintenance / Service 5 04-05-2012 11:03 AM
