Old 05-19-2018, 01:32 PM   #1
David C
Drives: White '07 3dr LB
An easy inexpensive solution I found was to double stack 2 pieces of 2x6 lumber and place them in front of each wheels and drive on them. You then effectively raise the car by 3" off the ground with all 4 wheels leveled and the lumber is strong enough to support the weight of the car. That additional 3" really make a big difference in term of clearance under the car. Cheap and quick, instead of buying ramps that have the car slanted.
David C is offline   Reply With Quote
Old 01-10-2019, 05:36 AM   #2
dogsridewith
Drives: 2007 2-door hatchback
Oil change ramps
On a part of my lawn that slopes just right, I drive the front wheels onto shallow plastic ramps. Vehicle is level. (What I do, w/ chocks and brakes. Not advice.)
Yaris oil change appreciation flagmunkey DIY / Maintenance / Service 18 07-19-2007 02:46 PM
first oil change? wushumasterku DIY / Maintenance / Service 41 06-07-2006 09:32 AM
