#1 | |
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
Synthetic
#2 | |
From my experience, most modern catastrophic engine failures are due to operators not checking/changing their oil, or a weak hard-part (design flaw). Synthetic oil will extend the oil change intervals, but you will still need to change the filter at a certain point and check your oil level. Believe it or not, I've found the most cost effective interval for my customers is 5000km with regular oil. Reasoning being that few people come in on time (probably 8K is about average and just about any engine can do that), and even fewer actually check their oil level. Many engines use up the reserve engine oil in about 5000km. |
#3 | |
https://www.cartalk.com/content/service-your-car-8 |
#4 | |
I've done oil testing on my Yaris since it has an unusual/hard life and settled on 8000km for the oil I use. I might be able to stretch it to 10,000km but it is not worth the risk to save ~$15/yr. |
#5 | |
![]() Drives: 2016 yaris Join Date: May 2018
Are you using synthetic or conventional? I was thinking synthetic should make 7500-10k Miles, but maybe I will re think that Sent from my moto x4 using Tapatalk |
Yeah roughly 5k Miles. Conventional oil. My car gets a lot of autoX and abuse, mixed with slow, local driving. I'd bet the typical Yaris coiuld stretch the oil life to 8k Miles easily, but can't say for sure. Testing isn't expensive. $50 or so per test. If you can extend your oil life with two tests, that $100 will pay off pretty quick (especially if you're paying someone else to do your service).
| Fuel filter replacement | jaimico | DIY / Maintenance / Service | 43 | 03-07-2023 11:05 AM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| Car shuts off when A/C turned on... | Howster | DIY / Maintenance / Service | 33 | 07-06-2013 05:00 PM |
| Beware WIX Filter #51394 | zkay | DIY / Maintenance / Service | 19 | 12-22-2012 12:09 AM |
| DIY - Cabin air filter location (Belta, Vios, Yaris sedan) | Murtaza_murti | DIY / Maintenance / Service | 5 | 04-05-2012 11:03 AM |
