![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
+1 on the great job man! Sorry to hear you ran into some trouble spots, but the photos really make it look like you've done a sharp job - that's gotta be worth at least a 50' job, lol.
As you said, big effort and lots learned - next time you'll be 10 steps ahead; be honest with yourself, you know there will be a next time.. ![]() Keep us posted on the fix-ups when you do them, and thanks for sharing the awesome job you've done, it's been enjoyable to follow. -- Adam |
#2 | |
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 07-08-2018 at 07:51 PM. |
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
I wish i wasn't on the wrong side of the pond otherwise i'd have you paint Betty.
![]() Sent from my SM-G930F using Tapatalk
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
I would love to!
'New' liftgate
Scored a used liftgate for $150.00 today. It will need to be stripped, primed, sanded and painted. Although the clear is flaking off, the liftgate has absolutely no dings or even scrapes. It is 100% rust-free. I think this car was 'decomissioned' very early in its life. I'm going to refinish this off the car and then bolt it on. It came with the factory style spoiler too! Of course I have no use for this as I'll be taking the wing off my old tailgate and putting it on the 'new' one.
If this is the original paint, I'm really getting WeeYari's and Kimona's point that the paint on these cars - at least the clear coat - is a joke. This stuff can't be thicker than a human hair - wow!
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 07-12-2018 at 08:48 PM. |
Hatchbacks for the win
Drives: Hatchbacks Join Date: Aug 2006
Thanks for sharing your experience, this is a great thread. You deserve a ton of credit for your hard work. It's inspiring!
#7 | |
The Saga Continues...
Well, I'm definitely getting better at spraying paint. Doing an orientation coat (pulling the gun back and dusting the metallics on immediately after my final med/wet base coat eliminates any mottling and my base coat is super smooth and uniform with the metallic flake all in the same direction. I am learning tons. There are parts of the car that look much better than factory with almost perfect metallics and a deeper, glossier look due to more clear being applied. However, everytime I do some painting something goes wrong. This time, two things...
1) I had sanded the clear coat down with 600 grit to spray the new base coat. In one tiny spot, not realizing, I had sanded slightly through the clear right at the front of the door, lower style line. The base coat immediately wrinkled. I let the base dry, carefully wet sanded it and then laid about 4 dust coats of base with 15 minutes between each. Then, I laid down my final medium/wet coats. This solved the problem. You cannot tell now that there was any wrinkling. 2) My gun must have had some silicone or other contamination. I got many fish eyes. I am hoping to be able to sand these out and then do a quick flow coat of clear in a couple of days. I am thoroughly enjoying this learning process. I am definitely improving but there is still much to learn and there are so many variables to contend with. ![]()
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 07-19-2018 at 02:51 AM. |
Let's just go big and call this pass a learning experience and do the whole thing over again when done! That way it'll come out perfectly
![]() Amirite?! Guys? |
#10 | |
I'm going to do the liftgate next. Maybe next summer, I'll respray the whole car, or find another one to do so I can continue to practice.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 07-19-2018 at 02:53 AM. |
| DIY: Painting Engine Cover | frownonfun | DIY / Maintenance / Service | 12 | 11-30-2013 11:07 PM |
| Stripping Paint Without Sanding | CrystalJean | DIY / Maintenance / Service | 1 | 10-06-2012 04:06 PM |
| Advice on paint booth | CAyaris | DIY / Maintenance / Service | 12 | 02-11-2011 09:37 AM |
| New 2007 Paint Condition | Pavel Olavich | DIY / Maintenance / Service | 16 | 09-13-2009 04:14 PM |
