Old 05-26-2018, 10:51 PM   #1
Runethecursed
Drives: 2009 Yaris S
From watching certain youtubers on positive ventilation, youd want the fans to have an after filter to catch stuff and even then... Ive seen better results with just a negative vent set up as the positive air tends to blow particulate on the paint.
Runethecursed is offline   Reply With Quote
Old 05-27-2018, 07:08 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
My main concern is evacuating the paint fumes/mist. The thought of being in a room that is full of toxic and potentially explosive fumes makes me nervous. I just feel that a negative pressure system will get the stuff out of there quicker. My theory is that the higher the concentration of paint vapours to O2, the higher the risks associated. I have two box fans and when I'm done, basically 1/4 the back wall will be a filter. I also have 2 pieces of 32" x 45" furnace hammock filter and will likely use it to cover the 6 filters for added filtration. That's 20 square feet of filtered intake and about 6 square feet of exhaust. I will play with the configuration until I get the best flow rate with maximum air removal and an acceptable pressure - aka not too much suction on the walls. Since I'm doing a base coat/clear coat, a few small dust particles are a minor concern. I will likely be wet sanding and polishing the clear afterwards anyway.
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Stripping Paint Without Sanding CrystalJean DIY / Maintenance / Service 1 10-06-2012 04:06 PM
Advice on paint booth CAyaris DIY / Maintenance / Service 12 02-11-2011 09:37 AM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
