Old 05-27-2018, 10:59 PM   #1
atomic_hoji
Drives: 2018 Yaris SE 5MT
Can't wait to see how this turns out, but so far it looks like you're on your way to an awesome setup.
I've done a few little paint projects with a basic HVLP setup in the garage. Regarding fans, I would imagine that you're best to to set the fans to draw through the filters and blow directly out of the garage - filter catches the particulate and you get the vapours right outta there. The trick of getting the floor damp does seem to help keep dust from getting kicked up by either a fan or the air from the paint gun if you happen to blow past.
That said, don't forget that if you're going to go through all the work of setting up a good paint environment that you'll need a decent quality filter / dryer on your air setup - the old beast of a compressor might leave oil in the air and I imagine your humidity is probably like ours (high, and miserable in the summer, lol) so there's a chance of water accumulation in the tank - both will impact your paint quality if they get pushed through the gun.
Of course, goes without saying, airflow and filters or not, please get the proper organic vapour P100 cartridge half-mask.
-- Adam
atomic_hoji is offline   Reply With Quote
Old 05-28-2018, 06:38 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
-- Adam
Thanks for all the awesome info! I did order a water/oil separator from Crappy Tire. It's not expensive so I hope it's up for the task. I'm also planning on getting one of those water traps that attaches directly to the gun. Yesterday, I placed a small order on Amazon, including a cheapie HVLP gun (as a backup and maybe for my primer), a 6000 series respirator with NIOSH cartridges (I now have 3 functional masks, though at least one probably has the filters at the end of their life).
My biggest concern is that my ventilation system will not work as planned; that I won't be able to get enough air flow. I want a negative pressure set up for quick evacuation but didn't want to spend a small fortune on expensive 'explosion proof' exhaust fans.
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Stripping Paint Without Sanding CrystalJean DIY / Maintenance / Service 1 10-06-2012 04:06 PM
Advice on paint booth CAyaris DIY / Maintenance / Service 12 02-11-2011 09:37 AM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
