![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Mar 2013
Could be a small stone stuck in one of your rotors. I had the same symptoms in my 07 sedan, even took a video to show the sound I was getting at low speeds. I had to take the wheel off, remove the caliper, and remove the rotor - and the stone fell right out onto the ground. Hope this helps.
https://youtu.be/79KPXKrsZao |
#2 | |
![]() ![]() ![]() Drives: Yaris manufactured after 2007 Join Date: Nov 2010
That might be the problem. I'll check. R. |
| Tags |
| low, noise, speed, tinkling |
| LOW RPM @Idle speed = Bad Volt Generation? | jp_costarica | General Yaris / Vitz Discussion | 4 | 06-14-2012 04:56 PM |
| Low road noise in Yaris? | RedRide | General Yaris / Vitz Discussion | 32 | 05-30-2010 08:49 PM |
| Low idle speed | gonzo452001 | DIY / Maintenance / Service | 9 | 02-21-2007 08:41 PM |
