![]() ![]() ![]() Drives: 1987 Silverado Join Date: Jan 2010
Yeah it had the problem before. That is the confusing part.
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
Well you can rule out the tires are the root cause. I'd say lift the front end of the car, put it on jack stands, get yourself a big prybar and go hunting for loose/worn steering or suspension parts. I'd start with the inner and outer tie rod ends, and then move on the the front sway bar & links. If you just had a alignment done, I think the tech would have noticed a worn tie rod and passed that info along to you.
| Quick ratio steering yaris 06-11 | froger | Performance Modifications | 4 | 09-14-2016 11:01 AM |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
| Is highway wander caused by caster? | Snubba | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 46 | 05-23-2012 11:10 PM |
| Steering wander, adjusting EPS assist | Snubba | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 05-22-2012 05:39 PM |
| How much would you pay for a warranty supported steering wheel extension? (3d try) | wornways | General Yaris / Vitz Discussion | 36 | 09-16-2009 10:16 AM |
