Old 06-21-2018, 02:47 AM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Does this mean you are venting the fumes straight to atmosphere outside?
Check out my Build thread:
Old 06-21-2018, 05:48 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Not ideal, but yes. With an HVLP there is apparently less overspray due to high transfer efficiency and therefore less VOCs emitted. I will likely be putting prefilters on my exhaust fans to catch some of the overspray. All of the products that I will be using fall below the VOC emissions limits for my province. Canada has similar regulations to states like California, for example. I'm in a semi-rural area and there's a good distance between us and our neighbours. There are no kids other than mine in the immediate area and mine will be away at day camps when I do any spraying.
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Stripping Paint Without Sanding CrystalJean DIY / Maintenance / Service 1 10-06-2012 04:06 PM
Advice on paint booth CAyaris DIY / Maintenance / Service 12 02-11-2011 09:37 AM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
