Old 06-21-2018, 02:50 PM   #1
Captain Yaris
Captain Yaris's Avatar
Drives: 2016 Yaris 3 Dr Super White
Got it figured out, and now it’s alive!!!!!!!!!! I had to swap a wire that was just a plug with a ground with a different wire that included the ground and connection to the cruise control unit. A special thanks to DarkShadowFox for hyperlinking that video of the Rostra install. It gave me the idea to pursue the correct wire from Toyota. Thanks for the help.
Part numbers to install on US Spec 2016 Yaris L are as follows:
Cruise Control Switch (84632-08021)
Clutch Switch; for cars with manual trans. (8820-42010)
Steering Wheel Switch Cover (45186-0D150-C0)
Cruise Switch Wire (84633-02020)
Cruise Control Switch Screws; need 2 of these. (90159-50199)
File Type: jpeg 4AB0BF84-8153-4B63-B522-72276B4A09F7.jpeg (207.3 KB, 369 views)
File Type: jpeg A52410CA-9F2A-4CF7-BB71-48548B662609.jpeg (164.6 KB, 359 views)
Captain Yaris is offline   Reply With Quote
Old 06-21-2018, 03:10 PM   #2
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
LMAO JFC dont tell me even the L gauge cluster has a spot for the cruise control omfg. they are ripping people off on these yarises lmao.
DarkShadowFox is offline   Reply With Quote
Old 06-21-2018, 03:16 PM   #3
Captain Yaris
It sure as hell does!
Old 06-21-2018, 04:33 PM   #4
DarkShadowFox
DUMMM. o well i wanted power locks and the rear lock squishy panel vs a manual lock and im not going to be the one to make a thread on how to install that. thats more money then you save on buying an L .
Old 08-23-2018, 03:16 AM   #5
vigvoodoo
Drives: 2016 Toyota Yaris L
Will this work for:
2016 Toyota Yaris L base model
Automatic
Touchscreen
No steering wheel controls
vigvoodoo is offline   Reply With Quote
Tags
cruise control. 2012
