Old 06-28-2018, 10:51 AM   #1
Fronts are much easier once you know the secrets. The rear are dead easy.
Old 06-29-2018, 11:04 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Ah ha. I am all ears for the secrets. The rear lights involve a bolt/screw behind trap doors in the rear panels, do they not?
Thanks.
Old 06-29-2018, 11:34 AM   #3
Thanks.
Well... I really wouldn't say there are any secrets. Just gets easier 2nd + times. Just the 7 push pins and the grip'n'rip on the corners. I still get butterflies every time I yank on it. Swear I'm going to rip the clips to shreds. If you pop the headlights out, you will at least know your not painting over whatever crap may be under the lower edge. Also, you will be able to tuck away the overlap of the fender liner.
Correct on rear.
Old 06-29-2018, 12:21 PM   #4
06YarisRS
Correct on rear.
I get it re: worring about damaging the clips. I also worry about flexing my bumper too much with my new lip as it does have some filler on it. So, I think I'll reserve removing the headlights for the necessary bulb replacement at this point. Rear lights, I will have a look at. Cheers.
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Stripping Paint Without Sanding CrystalJean DIY / Maintenance / Service 1 10-06-2012 04:06 PM
Advice on paint booth CAyaris DIY / Maintenance / Service 12 02-11-2011 09:37 AM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
