Old 06-29-2018, 09:11 AM   #1
atomic_hoji
Drives: 2018 Yaris SE 5MT
Great job so far!
Everything I've read says prep work is probably 10x (guestimate) the effort of what you'll put into actually priming and painting, but worth it when you're paint comes out looking great. Nothing shows an amateur (or poor shop) job like paint on trim, seals, windows, etc.. because they did a rush job prepping.
Keep up the great work, can't wait to see the end result!
--Adam
atomic_hoji is offline   Reply With Quote
Old 06-29-2018, 11:12 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by atomic_hoji View Post
Great job so far!
--Adam
Yes, I've heard too that it's largely in the prep work. One thing I did do was remove the belt moulding - and ruined one in the process. Both front ones were pretty gouged up anyway presumeably by an agressive ice scraper-wielding previous owner. I've ordered a new pair.
I think I'll pop the tail lights off as Wee Yari says they're so easy. If he reveals the secrets about headlight removal, I may do those too. That said, I have them taped pretty well and paint should get in well between the lights and panel edges. Then again, I already have half the interior stripped out of the car anyway.
Thanks!
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Stripping Paint Without Sanding CrystalJean DIY / Maintenance / Service 1 10-06-2012 04:06 PM
Advice on paint booth CAyaris DIY / Maintenance / Service 12 02-11-2011 09:37 AM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
