![]() ![]() ![]() Drives: 2007 Yaris Liftback, 5-speed Join Date: Oct 2006
The OEM head unit doesn't sound too bad to me. I'm thinking of keeping it (or getting the Canadian Yaris RS 6-disc changer/receiver) and using Pioneer Premier TS-D701P 2-way speakers in the front and Pioneer TS-A1781R 4-way speakers in the rear. Both speaker models are oversize (6 3/4") and both are rated for a sensitivity of 91dB (so I'm thinking that the OEM unit's power should be enough to drive them).
Any thoughts? I'm looking for a low-cost upgrade that will give me a fuller sound, more clarity, and a lot more bass without adding a thumping subwoofer.
'07 3-door Meteorite Metallic Liftback: manual transmission, power package, 60/40 split fold-flat rear seat, ABS, side airbags, keyless entry, fog lights, 7-spoke 15" Toyota alloys, cruise control, TRD sway bar. |
#2 | |
The addition of the bright pioneer tweeters will give a sense of "clarity" (although they really aren't "clean" by any means), but I suspect bass output wont increase much if at all. There are speakers capable of giving a low end similar to a subwoofer, but all of them will require an amp. Your much better off adding a set of tweeters to the stock setup, and mounting on the A pillar, it'll yield more of an overall improvement than anything you can do at this point, short of adding an amp. If you can deal with less output, go for a lower end componenet set (as opposed to the kappas listed above, the reference series would be a better choice)... will definitely yield improved quality across the board. |
#3 | |
I'd also be interested in what speakers you feel would add low end similar to a subwoofer (I've pretty much decided against adding a sub; I need the room in the back for my dogs). I'm looking to invest $500-700 here, including installation. I should also mention that most of the music I'll be playing is blues, '50s-'60s R&B, and early/classic rock. So I don't need hip-hop style bass thump.
#4 | |
You should be able to accomplish your goal within that budget - put your $ into a quality 2 channel amp and quality front components, instead of a 4 channel and all new speakers and you will get the sound you desire :) |
#5 | |
![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2006
| Can I install these speakers to the front and rear of my liftback? | W.A.S.P | In Car Entertainment + Electronics (audio / video / alarm) | 33 | 02-25-2009 02:23 PM |
| X'Mas Special - Aeroparts for the Vitz | MC-BPT | Sponsors Classifieds Area | 24 | 01-11-2007 09:39 AM |
