Old 07-06-2018, 08:57 PM   #1
tmontague
tmontague's Avatar
Great job, what do you mean the paint isn't as good as oem - what did you notice was different?
Old 07-06-2018, 10:25 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Thanks! Because I didn't sand enough the metallic flake didn't settle uniformly. In certain lighting, you can see the rougher texture. The metallic isn't completely uniform across all panels of the car. I think my spraying is not bad and if I'd had a truly smooth surface, it would have been more uniform and 'flatter', less peel effect. The primer went on quite peely and despite a fair bit of sanding - and it feeling smooth to the touch - it resulted in a somewhat textured base coat in areas.
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Stripping Paint Without Sanding CrystalJean DIY / Maintenance / Service 1 10-06-2012 04:06 PM
Advice on paint booth CAyaris DIY / Maintenance / Service 12 02-11-2011 09:37 AM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
