Old 07-08-2018, 09:25 AM   #1
atomic_hoji
Drives: 2018 Yaris SE 5MT
+1 on the great job man! Sorry to hear you ran into some trouble spots, but the photos really make it look like you've done a sharp job - that's gotta be worth at least a 50' job, lol.
As you said, big effort and lots learned - next time you'll be 10 steps ahead; be honest with yourself, you know there will be a next time..
Keep us posted on the fix-ups when you do them, and thanks for sharing the awesome job you've done, it's been enjoyable to follow.
-- Adam
atomic_hoji is offline   Reply With Quote
Old 07-08-2018, 05:47 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
-- Adam
Thanks Adam! I've decided to respray the passenger doors as they are the worst. I'll sand with 600 first and hopefully the clear will sand smooth enough to lay a couple of base coats and 3 clear coats. I have enough material remaining to do that. I will definitely post up the process.
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Stripping Paint Without Sanding CrystalJean DIY / Maintenance / Service 1 10-06-2012 04:06 PM
Advice on paint booth CAyaris DIY / Maintenance / Service 12 02-11-2011 09:37 AM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
