Old 05-02-2007, 06:27 PM   #1
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
I bet your rpm is alot higher then its supposed to be,in 1st 2nd and 3rd,untill you get up to speed,this is where the weight of the rim bennifits your car,more rotating mass thats already spinning,this gives the car a high forward momentum,which helps ease engine load,the faster your going the better(for this effect,be safe ofcourse).But check your rpm going uphill
eco is offline   Reply With Quote
Old 05-03-2007, 10:34 AM   #2
spkrman
Drives: 1
Well the rpm is going to be a bit lower for the same speed across the board, but it does take more effort to get goin.
I've noticed that my MPG figures remain the same (31-33) whether i'm going 80+ or cruising 55... before cruising 55 would get me 35-36mpg.
Originally Posted by churp View Post
I agree with the 3600 at 70 in the MR2.....but with the dubzzz on the Yaris did you recalibrate your speedometer to account for the larger diameter tires, calculate from the ratio of the diameter difference, or just guessing about your speed?
Going off the post here that noted there is a 6% difference, its just an educated guess :)
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
