Old 07-15-2018, 02:29 PM   #1
tmontague
tmontague's Avatar
To loosen and realign simply undo the 14mm (or 17mm I can't remember) bolt on the bottom of the rear shock/axle and then from the inside loosen the upper shock bolt. You can then move the bump stop as you wish
Old 07-15-2018, 02:35 PM   #2
meteor
Drives: hatchback manual transmission
Awesome, do you think I'll need anything more than a breaker bar for the bottom? Also should it be on a jack? I'll try and report back today with the results.
meteor is offline   Reply With Quote
Rear Wiper Intermittent Delay Timer Mod toy_toronto DIY / Maintenance / Service 36 07-08-2016 08:04 AM
FS Cusco coilovers, ultra rear sway, gt spec bracing, miracle x cross bar seibon hood blacksandiegovitz Items for Sale by private party 23 10-24-2015 11:47 AM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
